How difficult is it to remove and replace each time? Thinking about that, I might as well replace any that I have to remove at any point. Is the upper or lower particularly hard or pain in the butt to replace?To refill, I take the heater hose off the back of the head and, using a funnel, pour your coolant in. This way there is no air trapped in the head that is difficult to get out.
BTW, I apparently had 0 issues with needing to burp. Didn't need to at all.
Just straight up poured it in. Maybe the first of all the gallons without a funnel, but the rest were with one. Now I've only driven long enough for the thermostat to open for a few minutes so far, but I never noticed any oddities with the temp gauge each time I did this.Out of curiosity, how did you fill it?
Sooooo, guys, is the petcock issue one where it has a verrrrrrrry slow drip? I got the flush done the other day and it seems to have an extremely slow drip. If I turn it very very slightly towards the open direction (rather than full tight), it doesn't seem to do this, but I don't have faith it will stay in any fractional position. I wonder if some wax or something that could take enough potential heat, would hold it in place or even plug the end?
Reckon I'll have to buy one then. Thanks for the info.I followed the procedure set out by AH64ID and ended up with the same slow drip at the petcock. I got a replacement petcock (not expensive) at the Dodge dealer, drained the radiator again, installed the new petcock, and filled the radiator back up with no further leaks. The rubber seal on the petcock was cracked causing the leak. When I do this procedure again I will follow the same procedure but get a new petcock and just replace the old one as part of the procedure.
Not hard at all. Just a hose clamp and pull the hose out of the way while inserting a funnel.How difficult is it to remove and replace each time? Thinking about that, I might as well replace any that I have to remove at any point. Is the upper or lower particularly hard or pain in the butt to replace?
