Engine/Transmission (1994 - 1998) whats the best way.....
Engine/Transmission (1998.5 - 2002) Bad lift pump out of the box?
2nd Gen Non-Engine/Transmission abs rear wheel sensor
to keep the fuel pump set at a certian MM lift
I set my timing once but I think the pump may have sliped a bit I want to do it again but I wanted to ask first how would you recomend keeping the engine/pump shaft from moving once you get TDC and whatever MM pump lift??
