Since the compressor runs when using defrost, and the A/C isn't a heat pump what is the difference between running your A/C and the defroster set to cold? Sometimes when driving at night, regardless of temperature but related to humidity the inside of the front windshield will fog up. When it's too warm to run the defroster on warmer settings I set it all the way to cold. The dryer air clears the fog and the only difference I can think of is that the air is being directed out of the top of the dashboard instead of out the front vents. Is this the only difference or is something more going on?
