What's the matter with my AC?
help with passenger side lights.
20" Wheels and 325 60 20 Tires on a 05 2500
Hello all.
My AC blows cold (very cold) for about 5 minutes, then warm and damp for five minutes, then cold again.
This ain't normal, I know. Any ideas before I bring it in?
Thanks all.
Dave
Ac
I would guess from the color of your truck in your signature that it is an 03? :cool: The temperature of the AC when everything is working correctly is determined by the clutch cycling switch screwed into the side of the accumulator and is controlled by the blend air door in the system by allowing warm air from the heater core to mix with the cooled air. Usually when a system is freezing up it won't thaw out till the AC is turned off for a while. Sounds like the clutch cycling switch may be malfunctioning. To check, turn the AC on and watch the compressor clutch, it should stay engaged while idling when the outside temp. is in the upper 80/90 degs. If it runs for the "5 minutes" then cuts off and stays off for "5 minutes" the switch is probably bad. bg
I have the same problem. I asked about it last time I was at the dealership but got no answers. From searching here I read about a
Fin Temp sensor
bad orifice Wich one do I tell them is causing the problem?
3 psi overcharge
bad check valve
Does anyone have a deffinitive answer on the 03 ac freez up problem?
CClements said:
Fin Temp sensor
3 psi overcharge
bad check valve
My ex-wife had a bad orifice, and her check valve was definitely malfunctioning. But both of these made her very frigid, so I don't think they are the problem. Complaining about it did no good, so I traded her in for a new wife. :-laf
