Whats the torque specs for the turbo to manifold bolts?
Rust in Tank
Latest reflash
RSchwarzli
Pulling the turbo off the truck for pyro tapping and inspection. Got the new gasket for install, but not sure how tight to re-torque the bolts.
Is it the same as the 12v's or different?
Thanks!
Robert
Didn't paste that good, so first number is N. m, second is either Ft. lbs or In. lbs. Use common sense if you can't make the conversion.
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Bolt-Adjusting Strap 23 - 200
Nuts-Air Heater Power Supply 14 - 124
Bolts-Air Inlet Housing 24 18 -
Nuts-Cab Heater Supply/Return Line 24 18 -
Nuts-Exhaust Clamp 54 40 -
Bolts-Exhaust Pipe to Manifold 31 23 -
Bolts-Generator Mounting 41 30 -
Bolts-Charge Air Cooler Mounting 10 - 90
Nuts-Charge Air Cooler Duct 11 - 95
Bolt-Generator to Block-Diesel 24 18 -
Nuts and Bolts-Heat Shield 11 - 95
Nuts-Heat Shield-Diesel 24 18 -
Differential Pressure Sensor Tube Nut 30 22 -
Differential Pressure Sensor Mounting Bracket nuts 10 - 89
Turbocharger Speed Sensor - (6. 7L Diesel) 3 - 27
Turbocharger Actuator - (6. 7L Diesel) 10 - 89
Electronically Controlled Wastegate Command Valve - (5. 9L Diesel) 34 25 -
Turbocharger flange studs - (Diesel) 24 18 -
Nuts-Turbocharger Mounting - (Diesel) 43 32 -
Bolts-Turbocharger Oil Drain Tube - (Diesel) 24 18 -
Fitting - Turbocharger Coolant Supply line - (6. 7L Diesel) 24 18 -
Fitting - Turbocharger Coolant Return line - (6. 7L Diesel) 24 18 -
Fitting-Turbocharger Oil Supply Line - (Diesel) 36 27 -
Torca Clamp Nut 54 40 -
Nut-Turbocharger V-Band Clamp Cast Elbow to Turbocharger -( Diesel) 8 - 75
Nut-Turbocharger V-Band Clamp Cast Elbow to Turbocharger - 6. 7L 11 - 97
Nut-T-bolt Clamp Cast Elbow to Exhaust pipe - (Diesel) NOTE: This is a One Time Use Only Nut - 5. 9L 11 - 97
Nut-T-bolt Clamp Cast Elbow to Exhaust pipe - (Diesel) NOTE: This is a One Time Use Only Nut - 6. 7L 16. 9 - 150
Turbocharger Oil Supply fitting at Turbocharger - (Diesel) 36 27 -
Turbocharger Oil Supply fitting at lube filter head - (Diesel) 24 18 -
