I was cruisin down the freeway @ 55 (not towing or hot roddin) when a slight pop sounded and a shudder felt then no gears whatsoever.
I know about the 5th gear nut loosening and allowing the gear to slide away.
But I have no response out of ANY gears. The gear shift will feel like it's moving gears around just like normal -- but nada thing when the clutch is dis-engaged.
Are the input shaft splines completly striped?
This has been a very smooth shifter till the very end.
Any suggestions;
-Rebuild it? (It has 220k miles)
-Buy new (Are they still sold new)
-Buy rebuilt (Then by whom)
While I'm at it what 'stock feeling' clutch should hold 400-450 hp (I have a PDR turbo installed and a #10 and 3k in the box waiting for a proper clutch)
Any ideas will be much appriciated.
dj
Any suggestions;
dj
