millssb said:Any diesel with glow plugs or grid heaters you do not want to use starting fluid because basically you have a giant hair dryer that's red hot in your intake manifold and when the fluid hits that it goes boom! It won't be pretty never done it myself but I know how flammable starting fluid is so I'm not going to try.
llook said:Starting fluid glazes the cylinder bore where the rings travel. Over time you loose compression in the cylinder
Vaughn MacKenzie said:ASTAR I don't know why you'd have to use ether to start your truck,
Vaughn
Vaughn MacKenzie said:Man Larry that would've been something to see![]()
I have a cruddy '82 Blazer that I used starting fluid on until I fixed the glow plugs. It didn't rev up that much even with a pretty healthy squirt. Another thing I used was WD-40 and also engine degreaser to help it start, but when that lit off it was very violent
One easy solution on using starting fluid on a Cummins. . . simply disconnect one of the small wires on each of the two grid heater relays, that'll keep them from coming on.
Vaughn
