Problem?
Seeing all the figures reported for intercooled W250's (ranging from 18 to 22 mpg) makes me wonder if mine is extra thirsty for some reason, or maybe it's driving styles.
When I first bought mine this past summer, it would get 17-18 on 285R-75/16 all terrain type tires.
Just to experiment, I ran a tank on the stock-size (235R85/16) set of tires I got with the truck, and got just a hair under 19.
Later, I turned up fuel, then replaced tires and wheels with 33x12. 5x16. 5 BFG mud terrains on aluminum wheels. It has been getting 16-17 since then. When I tow heavy, I get about 12. When I run mostly highway (empty), it gets about 17.
I suspected dirty injectors, so I started using Power Service diesel fuel supplement + cetane. It does make the engine run noticeably better, but didn't effect mpg as far as I can tell. After a couple tanks of the supplement, the engine runs much smoother at low RPM which tells me it has cleaned the injectors.
I don't hot rod very often, but I do like to feel the power now and then, or fog a tailgater.
I normally run 60-65 mph. I like the low end of the Cummins and use it by shifting at fairly low R's. Soon I hope to have a 12 cm housing which should help me there.
Anyone have any ideas where my fuel might be going? I have a feeling it has to do with my new tires.
