2nd Gen Non-Engine/Transmission Wheel bearing run tight
2nd Gen Non-Engine/Transmission Bleeding brakes with ABS
2nd Gen Non-Engine/Transmission AFE Stage 2 install problem
Just got off phone w/service manager. Had taken truck in for leaking front axle seal. Bearing had run tight, hub may be ruined, parts on order, no truck till Thursday. No indication of a problem with bearing, no grinding sounds. Guess I'll have to run the CJ7 to work this week. I assume this is covered under drivetrain warranty?
It should be covered if you have less than 36,000 miles unless you have the extended warranty. The mighty Cummins has a 5 year 100000k warranty. That is, unless they increased the Dodge warranty in the 2002 and later trucks.
