Sounds like your narrowing it down, but something else to watch is the steering gearbox mounting plate on 4x4's. The one on my last '92 broke at the front mounting hole, allowing the front of the gearbox to walk side to side and cause the death wobble. Pretty much the same effect as a badly worn tie rod, drag link, etc. It cracked the frame aroud the hole pretty bad, too. Had to weld it and reinforce with a big washer. 2wd's don't use the plate, the gearbox bolts direct to the frame, so they don't seem to have that problem...
Andy
