Wheel interchange, 1st/2nd gen SRW
Oil Leak HELP!!!!!!
How long do B5.9 head gaskets last?
Got a couple of good Michelins mounted on 2nd gen wheels that I need for the fronts of my 91. Does the change in lug size affect the swap or will they fit properly?
As long as you use the correct angle-seat lugnut, such as factory lug nuts, they should work. Offset is different, so it will affect your toe-in a little. The center caps won't go on and stay unless you make some correct lug nuts.
They work fine as long as you use the conical type oversized lug nuts that chrysler had on lots of it's vehicles. I didn't notice a different offset, as IIRC the backset is still 4. 5" on the newer rims.
http://www.dieseltruckresource.com/...rims-1st-gen-t147764.html?&highlight=gen+rims
NAPA part number 6411549 is for the 1/2 stud that is a direct replacement for the Dodge part number
http://www.napaonline.com/Catalog/R...k=Keyword&Nty=1&Dn=0&D=641-1549&Dk=1&Dp=3&N=0
