Archived Wheel joints
Archived A. C. Compressor Removal
Archived Won't Start
I started taking the front end apart to change the left axle u joint. I do not have a shop manual and I would like it if someone could give me the torque values to reassemble. Also what size socket is the large nut on the axle. 03, 3500 4X4 Thanks.
Hi,
If you are just changing the u-joint you can leave the big nut on the axle tight. take out the four bolts (from the backside) that hold the hub/bearing to the knuckle. you can pull out the hub/bearing with axle shaft attached, change universal joint and reinstall. that way you don't change the preload on the bearing and less chance of the bearing "coming apart" during removal. This has worked well for me many times, might give it a shot.
Dave
