Details here: TDR Privileges
Ok here is a noise that I can not figure out. When I put on my brakes I am getting a clicking sound from the driver side rear wheel. Sounds like a rock in the tire but when I let off the brakes the noise stops. Have any of you had this problem?
It sounds like you have a hard spot on the rotor, or a break shoe that has come loose and is flopping. !!!Take off the break shoes and spray the brake shoe with the CRC Chem Disc Brake Quiet rubber coating (or Sta-Lube 05016 BRAKE QUIET ($3. 98) @ Advance Auto) and see if that fix the problem also look to see if there is any cracks in the rotors
