Wheel question
Cruise Control Install Procedure
Front pinion seal
I know the stock BS is 6. 25", and as most know the rims that most would want have 4. 5". Is the problem using less spacing only noticed with bigger wheels or does that make a difference? I am have a few ideas rattling around in my head but I a leaning to keeping the height stock but mounting up 33x12. 50's. Would they be a problem on rims with a BS of 4. 5"?
Strick69
I am running H2 wheels with the 4. 5 in backspacing and it has worked just fine. Moves the centerline of the tire out 2 inches, prevents the 35 inch tires from rubbing on the lower control arms the way they did on the stock rims!
