Keep in mind that wheel steps are one destructive device if you move the truck and fail to take them off. After having two tilt fiberglass front ends torn up, I took them away from lube man and had plywood steps built. Always seems to happen on the off side. He would put them on to clean windows and then go do the paper work, come back to truck and back it off the hoist with step attached on right side.
Anybody have concerns about small wires (battery, brake and ground) used in the trailer wiring harness?
