Wheels and Tires
Quiet Cummins
Just DROVE a 2004.5 HO
final ratio
I tried to compute this, but it made my head hurt. 2002 standard diff ratio is 3:54 with 16 inch wheels. 2003 standard is 3:73 with 17 inch wheels. Assuming a 2002 shows 2000 RPM at 68 miles per hour, what would be the RPM for a 2003 at the same speed?
Thanks for an answer.
The 3500 dually that made the auto show rounds was wearing LT235/80R17E rubber. No difference in height between that and the 2002's LT235/85R16E, just a one inch wider hole in the middle.
If you're turning 2000rpm with 3. 54s, you'll be at 2100 with 3. 73s.
Re: If I rember correctly
Originally posted by fireman56
235R75-17, with 265R75-17 as an option on 2500s.
Fireman
not too bad. 33's as factory tires on the srw [well, 32. 649"] does anyone know what wheel size it will have. will the srw be 17x8'?
i wonder how much lift is needed to clear 37x12. 5x17 bfg's or mt/r's??:D
'03 Tire Size
When I placed the info for the TST order for the '03 3500 HO 6 speed with AR9 Single Rear Wheel Group, the tire option shown is TS5 LT235/80R17E OWL On/Off
