wheels studs, need help
D
To rotate or NOT to rotate (DRW)
AAM 11.5, carrier gears damaged
so here's my dilemma; i discovered 3 broken off studs (sans nuts) the other day. went to napa and bumper to bumper (the only auto parts stores within close proximity to me) and got new wheel studs, much to my dismay they are a good 1/2 longer than the stockers! both places list the same ones and those are my only options so i put them on. now i cannot fully tighten down the nuts because of the extra length (my studs are the closed end style to fit my aftermarket wheels). i am short on time and was thinking of zipping them off to proper length and filing, if i thread a regular nut on first it should clean up the thread upon removal. does this sound like a good or bad idea? i'm just not so sure when it comes to something as important as wheel nuts.
Should be OK if you don't get them hot. Use an air die grinder with a cut off wheel, and run water on the stud as you cut it. Run a nut all the way down on it first, file or grind a chamfer on the stud before you remove the nut, and you should be good to go.
HEY!!!!! Listen, have you removed the small spur retaining clip/washers before you put on your aftermarket wheels? Probably not if you've broken some studs... the same thing happened to me.
The washers are on about every other stud; take a screwdriver and pry off the retaining washer. They're not used for anything except assembly purposes at the factory. If you don't pull these off, your studs will continue to break.
Rockauto has the factory studs... don't remember the number off hand. Dorman has a great online catalogue that you can match up the OEMs exactly.
--Eric
thanks guys, those washers are gone now to get at the studs, although i'm not understanding the correlation to the studs breaking? i'm gonna check out Dorman and order some extras just in case! :)
It seems trivial, but the OEM wheels have reliefs cut in the back of them to allow clearance for the spur washers... and most aftermarket wheels don't. This causes the wheel to not seat correctly and places too much stress on the lugs. They will break over time, as you and I and others have found out.
<TABLE style="BORDER-BOTTOM: 2px groove; BORDER-LEFT: 2px groove; BACKGROUND-COLOR: white; BORDER-COLLAPSE: collapse; BORDER-TOP: 2px groove; BORDER-RIGHT: 2px groove" class=main><TBODY><TR><TH>2007 DODGE RAM 3500 LARAMIE 5. 9L 359cid L6 DIESEL FI Turbo (C) OHV : Wheel/Tire : Lug Stud Wiki</TH><TH>Price</TH></TR><TR id=table432part0 class=part0><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>DORMAN Part # 610383 {#4746916, 6103831, 970351} Serrated Stud; Thread; 9/16-18; Knurl Dia. : . 643"; Length: 3-5/32"; Shoulder Length: 1"
Rear</TD></TR></TBODY></TABLE></TD><TD style="HEIGHT: 40px" class=right>#ad
</TD></TR><TR><TD class=center colSpan=2>Choose: <SELECT size=1 name=optionchoice><OPTION value=0></OPTION><OPTION selected value=1>($1. 98) {10}+</OPTION><OPTION value=2>($2. 30) {1}+</OPTION></SELECT></TD></TR><TR><TD colSpan=2>+ Sold in packs of {x}; Price reflects cost of each individual item, not the pack</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node432part0price class="center leftrightborder boldfont priceonly alternate0">$1. 98</TD></TR><TR id=table432add0 class=part0><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate0 center">Add to Cart See Options at Left</TD></TR><TR id=table432part1 class=part1><TD class=alternate1 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>RAYBESTOS Part # 28903B Professional Grade; Wheel Stud
Front; Outer; Four Wheel Drive (4X4); Dual Rear Wheels; 8 Lug Wheels</TD></TR></TBODY></TABLE></TD><TD style="HEIGHT: 40px" class=right>#ad
</TD></TR><TR><TD colSpan=2>+ Sold in packs of 5; Price reflects cost of each individual item, not the pack</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node432part1price class="center leftrightborder boldfont priceonly alternate1">$2. 07</TD></TR><TR id=table432add1 class=part1><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate1 center">Add to Cart </TD></TR><TR id=table432part2 class=part0><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>DORMAN Part # 610439 {#5015229AA, 6104391, 970691} Serrated Stud; Thread; 9/16-18; Knurl Dia. : . 658"; Length: 2-7/16"; Shoulder Length: 7/16"
FRONT; 4WD</TD></TR></TBODY></TABLE></TD><TD style="HEIGHT: 40px" class=right>#ad
</TD></TR><TR><TD colSpan=2>+ Sold in packs of 10; Price reflects cost of each individual item, not the pack</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node432part2price class="center leftrightborder boldfont priceonly alternate0">$2. 22</TD></TR><TR id=table432add2 class=part0><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate0 center">Add to Cart </TD></TR><TR id=table432part3 class=part1><TD class=alternate1 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>WAGNER Part # BD125886 Wheel Lug Stud
Rear (Only 5 Remaining)</TD></TR></TBODY></TABLE></TD><TD style="HEIGHT: 40px" class=right>#ad
</TD></TR><TR><TD colSpan=2>+ Sold in packs of 5; Price reflects cost of each individual item, not the pack</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node432part3price class="center leftrightborder boldfont priceonly alternate1">$2. 26</TD></TR><TR id=table432add3 class=part1><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate1 center">Add to Cart </TD></TR><TR id=table432part4 class=part0><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>DORMAN Part # 610471 {#5096144AA, 6104711, 972151} Serrated Stud; Thread; 9/16-18; Knurl Dia. : . 645"; Length: 2. 52"; Shoulder Length: 0. 459"
Front; RWD</TD></TR></TBODY></TABLE></TD><TD style="HEIGHT: 40px" class=right>#ad
</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node432part4price class="center leftrightborder boldfont priceonly alternate0">$3. 20</TD></TR><TR id=table432add4 class=part0><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate0 center">Add to Cart </TD></TR><TR id=table432part5 class=part1><TD class=alternate1 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>WAGNER Part # BD125964 Wheel Lug Stud
FRONT; 4WD</TD></TR></TBODY></TABLE></TD><TD class=right></TD></TR><TR><TD colSpan=2>+ Sold in packs of 5; Price reflects cost of each individual item, not the pack</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node432part5price class="center leftrightborder boldfont priceonly alternate1">$3. 79</TD></TR><TR id=table432add5 class=part1><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate1 center">Add to Cart </TD></TR><TR id=table432part6 class=part0><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>WAGNER Part # BD125985 Wheel Lug Stud
Front; RWD</TD></TR></TBODY></TABLE></TD><TD class=right></TD></TR><TR><TD colSpan=2>+ Sold in packs of 5; Price reflects cost of each individual item, not the pack</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node432part6price class="center leftrightborder boldfont priceonly alternate0">$4. 06</TD></TR><TR id=table432add6 class=part0><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate0 center">Add to Cart </TD></TR><TR id=table432part7 class=part1><TD class=alternate1 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>RAYBESTOS Part # 28946B Professional Grade; Wheel Stud
Front; Single Rear Wheels
Front; Inner; Four Wheel Drive (4X4); Dual Rear Wheels; 8 Lug Wheels
Front; Pickup (2 Dr. ); Two Wheel Drive (4x2); Dual Rear Wheels; 8 Lug Wheels
Front; Inner; Cab-Chassis (4 Dr. ) Crew Cab; Two Wheel Drive (4x2); Dual Rear Wheels; 8 Lug Wheels
Front; Inner; Cab-Chassis (2 Dr. ); Two Wheel Drive (4x2); Dual Rear Wheels; 8 Lug Wheels
Front; Pickup (4 Dr. ) Crew Cab; Two Wheel Drive (4x2); Dual Rear Wheels; 8 Lug Wheels</TD></TR></TBODY></TABLE></TD><TD style="HEIGHT: 40px" class=right>#ad
</TD></TR><TR><TD colSpan=2>+ Sold in packs of 5; Price reflects cost of each individual item, not the pack</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node432part7price class="center leftrightborder boldfont priceonly alternate1">$4. 88</TD></TR><TR id=table432add7 class=part1><TD style="PADDING-RIGHT: 5px; WHITE-SPACE: nowrap; PADDING-TOP: 5px" class="alternate1 center">Add to Cart </TD></TR><TR id=table432part8 class=part0><TD class=alternate0 rowSpan=2><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD class=partlayout>RAYBESTOS Part # 27894B Professional Grade; Wheel Stud
Rear; Dual Rear Wheels; 8 Lug Wheels</TD></TR></TBODY></TABLE></TD><TD style="HEIGHT: 40px" class=right>#ad
</TD></TR><TR><TD colSpan=2>+ Sold in packs of 5; Price reflects cost of each individual item, not the pack</TD></TR></TBODY></TABLE></TD><TD style="PADDING-TOP: 10px" id=node432part8price class="center leftrightborder boldfont priceonly alternate0">$6. 54</TD></TR></TBODY></TABLE>
Before you think all is well, take a good look at your wheels and the hub on the truck. ALL factory wheels center on the hub, so the hub takes the load from the wheel. If the diameter of your aftermarket wheel hub is larger than the truck hub flange and you do not have spacers to take up the difference, all the wheel load is being held by the studs and they will break again if they are loaded or impacted hard enough.
