When Changing injecters
Help! New thermostat running at 170
Does cutting off the muffler and cat void warranty??
When changing injecters what else needs to be done? Is it a simple drop in and starwheel/plate adjustment?
Injectors are a separate issue from AFC starwheel and torque plate adjustments. This stuff has been hashed many times; email me if you need details to save bandwidth.
Clean out injector holes with compressed air before removing and dont bend the fuel lines hardly at all, just kinda lift them outa the way making sure to remove all retaining brackets first. Different injectors work best with certain thickness washers, 370s use . 020 thick for best results.
