Thought I'd pose this ? to get a response from the TDR membership...
Was cruising around today when my truck cut out suddenly, and the check engine light came on. Truck came back to idle like I had shifted to Neutral. When I put it back in gear, it ran fine. Autozone couldn't pull a code out of it and after they hooked into it, the check engine light turned off and hasn't come back on.
Some of you might recall that just 2 weeks ago I got a new VP44, only to have the truck die on me one day for no reason. A new crankshaft position sensor seems to have fixed the problem till the event today.
After owning this truck for 4 years, these are the issues I've had with it:
1. ) Rear end went out @20k miles
2. ) Seat back release broke @ 40k miles
3. ) Lift pump dies @ 52k miles
4. ) Tcase seal @ 65k miles (replaced twice)
5. ) VP44 @ 76k miles
6. ) Crankshaft position sensor @ 76k miles
I figure I have a good truck, but I think I'm just victim to a generation #1 truck that still had lots of bugs in it. The sad part is I'm getting to the point where I don't trust the truck anymore and I'm afraid to take it very far. I'm wondering if it should be traded in for something new that has had 4 years to get debugged or if I should just stick with what I got and continue fixing things that come up.
When do you guys call it quits and go look for a new ride?
