I have heard many times that extended idling is not a good thing because the combustion chamber temperature can drop to the point of not being able to combust the fuel, resulting in a washdown of the cylinder walls. This leaves the walls without oil and can damage them.
On long downhill grades of many miles where there is no go pedal, my EGT's will fall to 200 degrees and less and I was wondering if the same thing occurs as extended idling. Or because there is no load on the engine, is all fuel delivery shut off when decelerating? Thanks for the help.
