2nd Gen Non-Engine/Transmission When wiring
Temperature gauges or fuel pressure gauges/senders, what gauge wire do you use? Do you prefer soldered connections or butt clips and that sort? TIA
John
Wiring
Soldering is best, I usually use the crimp type connectors but some of the generac brands are not too good. 18 ga. wire is sufficient for most gauge installation. bg
I've been using 18ga also. I've soldered that I could (switches), and used twist-cap things for the rest. I should probably go back and solder all my connections, but I don't want to rip my gauge pod out again. :cool:
Fuel pressure and pyrometers usually rely on very small voltages which are vulnerable to "noise. " For these applications, I would also suggest a twisted pair or shielded wiring.
I like to use 16 and 14 gauge for most of my wiring work. 18 just seems too thin and more likely to break from getting snagged on stuff, like when I cram my hand into a tight place when one of the wires happens to be there.
Inside of the cab, I usually just butt connect the wiring. I use electrician pliers to crimp them though, not those rinky-dink wire crimpers. Outside of the cab, I like to solder, but sometime use butt connectors and tape them up with some high-tech friction tape that bonds together to form a watertight/airtight seal over the connection.
Doc
What Doc said. Its easy to forget that in addition to carrying the voltage (or current) for the particular application, the wire must also 'preserve' its own integrity in a hostile environment (a truck) against pulling, shaking, and sometimes twisting or flexing. Generally a slightly larger gauge will improve 'survivability', and have a thicker jacket (in general) more resistant to puncturing and subsequent shorts.
