Where can I get DD2's?
starting problem
I'm Sorry...
Or you can try www.piersdiesel.com for the injectors. The injectors are pretty easy to install and come with detailed instructions on how to install. I would estimate 3-6 hours for the first time depending on your wrenching skills.
Charles
Jim - You'll get a "substantial" increase in power with the DDII's considering you already have an EZ box. I don't know how much dyno horsepower you'll get, but I'd guess 50 HP, 125 FT. LBS would be about right. Others with actual dyno results may be able to chime in - or look up the Diesel Dynamics "True Torque Power Module" aka TTPM dyno charts on the DD web site. The EZ and TTPM produce similar results.
I have -just- the DDII injectors, boost elbow, and boost module on my truck. I can hit 32 PSI of boost running up a hill empty. I can't imagine how fast I'd roach my transmission if I got an EZ or TTPM box to go with em. :D
Greg
Originally posted by jimnance
Since I already have the EZ and 4" exhaust installed, how much more power do you think I would make with the DD2's?
You'll be right at about 300hp (rear wheel) with DDII's and EZ.
