Matt42
I am having a terrible time with the A/C in my truck. I discharged it because I had to replace the heater core. Since it's as old as it is, I decided to also replace the evaporator core and the accumulator/dryer. See this thread for the whole story.
http://www.ackits.com/forum/messageview.cfm?catid=2&threadid=9835
I added 6 ounces of PAG oil, as directed by the Dodge TSM, evacuated, and filled with 32 Oz R134a. The system holds 7. 8 ounces of oil, total. It cooled somewhat and acted like I had too much oil in it.
I had discarded the old acucmulator, so I couldn't drain it to see how much oil it had contained. I got less than an ounce out of the old evaporator core.
Today, I took off the *entire* A/C system and drained every hose and part of oil. I got four (4) ounces, mostly from the compressor. About 1/2 ounce came out of the accumulator. I have gotten nothing from the evaporator core, and small amounts spilled from the hoses and aluminum lines that I couldn't measure. I got nothing from the condenser. I've blown out the lines and parts with dry compressed air, with a drop or two more. I've discharged it twice fast, and may have obtained some oil as mist.
Where is the oil? I didn't even get my six ounces back. Do I have to take the compressor apart to fully drain it? All I did was take off the hose fittings and upend it to drain. Has the oil coated the insides of the parts so that it will take some time to drain out? I am leaving the parts to drain overnight, with the fittings closed off with plastic bags and rubber bands.
This is very strange and more than a little annoying! I'll appreciate all suggestions and experience!
