Where do i enter the cab???
Air conditioning woes
Another Air Filter Question
Help please???/ i need to get some heavy wire from both batterys in the engine compartment through the fire wall into the cab::::::... . i have a 2003,,, 4x2 long bed ,,automatic trans. . what is the best place to go through the firewall???? Thanks... ... ... ... ... ... ... ... . doc
I have drilled a hole thru the plastic plate that covers the unused clutch linkage hole on the automatics to route all of my wiring.
Easy to get to both under the hood and up under the dash. :)
There is a rubber plug in the firewall that I used. It is easy to see if you look from inside. I have a stick so I'm not sure what it is for but I have lots of wires running through it already. Shadrach
