WHERE DO I SPLICE IN FOR GAUGE LIGHTS
Adding leather
FIVE WHEEL BRAKES!!!!
Where do i splice in for egt and boost gauge lights.
thanks
Jack
2K, 2500,Laramie,Quad,4x4,3:54LSD"slushbox 250 RPM drop WOT shifts", , reese 15k 5th slider, LAVERNGE BULL BAR,WESTIN NERFS, DD1's, VA, boost & elbow onboard, 4" & 9000's in transit w/more to come
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA,VFW,SASS
I pulled the feed off of my low beams under the hood behind to the driver's side headlight;
one problem, no gauge light when you got the brights on.
joe
Where do I splice in for egt and boost gauge lights.
<font color=blue>
Jack, you can tap into the power feed from the dashboard illumination circuit, which will then give you ganged dimming under the control of your dashboard illumination variable control. Checkout the circuitry associated with the #13 fuse.
JMc
2001 Flame Red Sport 3500 QC, 5. 9L 24v Cummins, 4x4 Auto, 3. 54/LSD, 155 inch WB, Agate leather, Camper Special Group, Trailer Tow Group, Sliding Rear Window, Line-X under the rails & underseal, Grover airhorns, Roadmaster XX, RS9000s, Reese Titan class 5 hitch, 60 gallon Aerotank.
[This message has been edited by JohnMcIntyre (edited 09-28-2000). ]
Look for the 5amp fuse, tie in there and you will be able to dim and brighten you gauge lights along with the dash. Not sure of the fuse # but the fuse panel cover has a list of the circuits.
You can buy an add-a-circuit at PEP Boys that will plug into the fuse block, cost about $9. 00 and is avaiable in the mini ato size. They require a slight modification to fit, where the blades slide into the fuse slot the plastic on the add-a-circuit is to thick. A little work with a file is all thats needed.
You can tie into the wires feeding the little light in the ash tray, that light also dims.
2001 SLT+,HO,6spd,4x4,SWB,QC,3. 54,every option except sport and roof marker lights. White w/agate leather.
Oem molded steps,Jacobs E Brake,Espar,Quad Headlights w/guards,Century Royal cap,Manik grill guard, class V hitch, Hide-n-side custom bed.
2000 Holiday Rambler 28'aluma-lite,TT, w/slide.
I easiest place I found is the feed for your radio. Take the facia off, 2 bolts hole the radio in, and splice into the orange wire for the "12v" with dimming and the single wire with a clip is a ground. Easy to get to, and simple to hookup.
CSCPusher
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package, Tow Package, SLT Laramie, 265's
It depends on where you are mounting the gauges. I have a pillar mount and found one of the wires on the the back of the light switch that was dimmer controlled and tapped into it. Saves routing wire all over the place IMHO.
TR
All fixed #ad
since the wire came righr down the pillar next to the fuse block just added a add a tap on fuse #5 ( 5 amp ) and is fed from the dimmer reostst on headlite sw.
Quick and easssssy #ad
thanks for the help guys
You never said which brand of guages you have. If it is isproo then you will want to run full voltage all the time. Their lites suck and need all the help they can get.
Gene-C
98 12V SLT 2500 4X2 AUTO,3. 54 limt slip rear, QC SB Driftwood W/color match Topper, Full alum Boards,Delux OE mud guards, Bugflector,SS Wheel well trim,Reese 15K slider hitch,30 ft. Coachman 5er,TST #8 plate TC lockup Sw,Trans-go kit,Heavy duty TC. Isproo Boost,EGT,and Trans Temp Guages,Hitco Exhaust Blanket, Uniden CB.
Yeah, I wasn't impressed with the Isspro gauges either. Switched to DiProcol
99' Qcab, 4x4, auto, chrome nerf bars, VA, Boost elbow, DiProcal Pillar mount gauges,
Gene-C
the egt ( most important ) is autometer, the boost ( just fills up the hole in the piller ) is isspro
Gene-C how do you like your exhaust blanket????
just ran outside( its darn near dark ) to check the lites, boy were you right about that isspro. . can't even see it. The autometer with the red condum really looks good.
[This message has been edited by JNutter (edited 09-28-2000). ]
Guage lights, eh?
Well the best way to do it is to center splice onto the TAN wire coming out of the headlight switch. This is the control wires for the dimming dash lights. Don't do the fuse tap thing... it is kinda rinky-dink, and will not provide as positive of a connection as a center splice is.
The orange wire behind the radio is also an effective way to get dimming power.
JNUTTER The Hitco exhaust blanket has worked out pretty good. It went on real easy and looks nice. I bought it for the noise reduction of which it helped a little. Whether its worth $100 or not I don't know.
jnutter , i hope the addition of an exhaust blanket will not void ... oih nevermind , did you post the outcome of your run in with DC/cummins or does your lawyer have a GAG order on you ? #ad
