Where Have All The Lube Points Gone??
New EGT guage and now different temps?
Cab Fresh Air Filter - Where is it?
Did an oil / oil filter / fuel filter change today and everything went normal. Then I stated to look for the lube points, on the front axle / steering linkage and couldn't find any. On my 2001 Dodge had gotten down to three lube points (one on the steering linkage and one on top of each steering knuckle next to the wheels. Guess this new truck doesn't need any lube. Did I miss one somewhere. . :confused:
some have a lube fitting on the double cardon joint on the front drive shaft [mine doesn't. . ] and there should be 2 grease fittings, one on the end of each tie rod. everything else is life of warrenty lube :(:(:(:(
