I am having an on-going problem with air getting into my fuel pressure gage and causing needle bounce. It is easy to bleed the air from the sending unit, but it's a pita to have to do it almost every day!
I believe this problem started shortly after the original lift pump was replaced, but maybe that's only coinicidence.
Recently, I had to replace the lift pump again... . this time I had a FASS pump (the one w/o the filters) installed. After the FASS pump was installed, my problem was greatly reduced... but not altogether cured, so I am scratching my head now trying to figure out where the air is getting into the system.
Help?
Help?
