Where is my fuel leak coming from?
Questions: changing cp3 & injectors
how bad do i need a fass system
I pulled in to work this morning and noticed a fairly strong diesel smell. I looked under the car and noticed a couple drops dripping off the front of the transmission. Where is this likely coming from? It is 14 degrees out right now, so I didnt investigate much further. Where should I start looking?
MH, check the return banjo bolt on the back of the head... 19mm IIRC, mine , I got 3/4 of a turn on, would only leak when cold, first start of the day usually. Oops, just PM'ed you on this !! Been awake for almost 3 days now. . time for some sleep!!
