Where the EDGE EZ plugs in at?
edge HOT
torq converters
Well after reading the directions on an EDGE EZ it says you plug one plug into the MAP sensor plug and the other plug goes into the Fuel Pressure plug on the RAIL. I am not having any problems with the MAP sensor plugs I know how that goes, But if you go to EDGE's website and read the instructions there for the EZ it says that one plug goes to the MAP sensor which i have that taken care of, but in question is the other plug and the other plug goes to the ECM DATA LINK plug... ... I am just wondering if i have the right EDGE EZ module?
So i guess my question is: Does the EDGE EZ use the ECM DATA LINK plug or the Fuel pressure rail PLUG?????
Here is the Website and scroll to the bottom and read on the EZ.
http://edgeproducts.com/dodge_600.html
I don't have the EZ, but I do have the Juice. The connector should go between the map sensor just like the the other connections. In other words remove the original map sensor connector and install the ez connector then connect the original wiring connector to the other end of the ez connector. Should be and inline installation. Hope this helps.
