Engine/Transmission (1994 - 1998) Where to buy engine rebuild kit?
Engine/Transmission (1994 - 1998) 5th gear c clip
Hi, im currently restoring a '95 12 valve, and have the engine torn down. Im thinking i may as well buy a whole rebuild kit after pricing out rings and bearings and gaskets individually (might be cheaper to buy a whole kit)
The engine has 496,000 km on it and everything inside looks good. Cylinders are all within . 0025" (top/bottom/90degrees) Any reccomendations on where to get a rebuild kit. I found a kit at the link below but not sure on quality. Thanks, kevin
Enterprise Engine Performance - 12V Cummins B Series Engine Rebuild Kit Kits
If it is still a good truck and you plan to keep it after overhaul my advice would be to buy OEM Cummins parts from an authorized Cummins dealer.
Enterprise Engines is about 2 hrs. from me & has built many engines for pulling trucks,he is a very good reputable shop here in Ohio. Just my 2 cents.
