Have been searching classifieds on several forums and keep coming up empty. Lots of regular EZ's available, but want to try the milder "timing only" setting of the Diesel Dynamics version TTPM. If anyone has any leads on one, I'm interested.
Also, in which order would you hook up the map sensor module when you already have a map sensor adaptor for the wire tap box? Does the wire tap box boost module connect to the Map sensor, then the TTPM's connect to it, or just not use one if you want "timing only"?
Thanks. .
Thanks. .
