Details here: TDR Privileges
I've tried with no success to find a 12v pump that will pump oil. I would like to rig a trans cooler and a pump to cool the oil when pulling heavy loads. Does anyone know where to find such a pump?
This is for cooling the fluid in a paxton supercharger. I'm sure the pump could be used to pump any hot oil. I would go with a little larger heat exchanger, and put a filter inline as well.
On the pro-stock I used to race, we used a belt driven pump on the rear end to circulate the rear end lube through a cooler. Just add some longer lines to reach the transmission and you're off to the races.
Have you considered the "other" option of Fast Coolers that add about a 1/2 gal of oil to the system as well as cool the oil with no moving parts to fail?
