where to get custom front coil springs?
Brake Pads: Performance Friction Z-Rated?
Exhaust Brake Prices
National Spring
619-441-1901
1402 N Magnolia Ave
El Cajon, CA 92020
Master Card, Visa, Discover
Not affiliated in any way.
Originally posted by 01turbododge
i was just wondering where i can get some coil springs custom made? if any one knows of a shop just let me know? thank you
chris
Welcome to the TDR! Not sure what your looking to do but have you checked out Skyjacker?
i have the skyjacker 5 inch lift on the truck already. i was wanting to go another 4 inches or more in the front. does any body know what i could do with the intercooler tube that go through the frame? i was wanting to do a body lift but cant untill i figure something out with the tube.
If you only go 2" instead of 3" on the body lift, you only need to cut the tube from intercooler to intake manifold. Turbo side the rubber elbow can be turned to fit. Mine is a 12 valve, not sure if 24 valve are made the same. No leaks with 40# of boost. You also have to cut radiator shroud. If you have an auto, 3" lift won't clear cooler line outlet, 2" will. What size tires you plan on running?
Brad
Originally posted by MJawsman
National Spring
619-441-1901
1402 N Magnolia Ave
El Cajon, CA 92020
Call National. They are the best. I have run them on all of my offroad trucks. Bullet proof. They build em for the pro's, Baja 1000 and such. Not too much either. I think it is about $500.
Anybody looked into longer control arms? I know the Skyjacker 4. 5" kit has longer arms, but what about lifts reaching into the 7"-10" range? Just a thought.
Just my 2 cents, but I wouldn't give Skyjacker the time of day anymore. Once they had my money, their customer service DISAPPEARED!!:mad:
P. S. I saw and ad for Valley Spring Works in Dixon, Ca that mentions customs spring applications, Dodge included. (707)678-3944
TRW for the best coil springs. You have to have the rate and free length though.
Triangle Spring for leafs. I had them make up a set of Trans Am (the series not the car) springs for my '69 Camaro from a blueprint.
