Where to get good quality Voltage regulator
Clutch and brake pedal bushings
VE Pump drive gear
I Have 2 first Gen dodge diesels and carry a spare regulator and replace one every few years between the two trucks. I used up the last 10 year old spare last winter. I bought the best one OReilly had and it lasted a whole week, the next one lasted a month and burned out all my lights when it stuck wide open. where can I get a good one?
Thanks
Hyperpack
there were basically 2 external regulators used by Chrysler from 1970 threw 1991. The first was a 4 amp the second was a 7 amp. The 7 amp was used on the big cars/trucks that had 100 amp alts on them.
No one makes the 7 amp anymore ! The 4 amp that is available today has crummy light weight electronics in them. They blow at the drop of a hat ! The diesel trucks grid heater will blow them instantly. I actually cut one of them apart to see what was inside. The electronic board was smaller than a match book cover. It was cooked to a crisp... I won't put up with this. I had some made that were 8 amp and include an adjustment potentiometer so the voltage could be set to suit the type of battery being used. I also use them to add on to trucks that have a bad built in ecm regulators . Anyone that wants one send me a
PM,...////MM
Thanks
Hyperpack
Gary , how much for the ones you have ? what about the ones used in the 60s dodges ive heard that the vovo ones were cloned and worked better
