Where to mount???
Trucks running great, no problems
Killer dowel pin killed!
New truck, ABS system under the hood, Not a lot of room.
Where/how do you mount the "Painless Wiring Kit" from Genos garage?
I mounted mine under the knee bolster (dodge calls it the steering column opening cover) to the right of the steering column on the horizontal metal support. Just take out the three screws on the bottom and carefully pull out on the panel or use a trim stick to remove it.
I mounted one under the dash on that metal support, and left the screws out of the underdash trim panel. Because I didn't wire a switch into the pillar SPA gauges, I sometimes need to pull the fuse for them, to program them without turning off the engine.
I've another under the hood, atop the factory fuse panel. The wires and relays I've added since then make it a little tricky to get the factory fuse panel on/off, so I plan to relocate the added wiring and fusebox to the other side of the engine compartment, where the factory airbox used to be.
-jon-
