funky rant
If you had a few hundred thousand to spend on legal fees and a few years to spend in court, you could probably WIN A WARRANTY CLAIM against Daimler/Chrysler.
As a matter of law--they have to prove that the product in question CAUSED the failure.
But as a matter of course, you're going to run into one of two situations. One, is the dealership that will say "warranty void" when you tint the windows. The other is one who'll "overlook" things like an EZ.
Problem is even if the local guys are cool about it and the product DIDN'T cause a failure--prying eyes and ears from up the ladder are going to cancel a warranty claim of any significant expense for ANY POSSIBLE reason. Why? The old corporate-- FU it's our bottom line we're protecting.
Personally I feel that it takes an IDIOT or a really big batch of bad luck to foul up the mighty CUMMINS. If you keep the oil clean, monitor the EGT's and supply fuel pressure, keep the fuel filter changed, let it warm up before romping on it, and use a little bit of common sense YOU STAND A PRETTY GOOD CHANCE OF
not needing to make a warranty claim.
Sure it'll sting a little if the VP-44 goes out, but that's what an emergency fund is for. And be damned if a STOCK VP would go back on mine. Perfect excuse to get a tweaked one.
Lift pumps are a regular warranty issue. For a warranty replacement you have to take it in and then they'll take a day to diagnose it, a day to get the part, and a day to put it on.
Or you go to Cummins with the part number and slap it on yourself in a couple of hours for $150 and some beer.
Transmission warranty is useless, it expires at 36k.
I don't need their warranty. If you can save some money and put it aside (like enough for a VP-44 and installation) then you can consider yourself SELF INSURED and let them stick the warranty. They'd be happier that way too. Don't need them monkeys under my hood. Let them do a reflash once--drove 70 miles to a reputable dealer when I have several closer to home.
NOW I'd call Rod at Wildcat Diesel or any of the TDR aftermarket performance advertisers. Don't forget your TDR discount. Or even better find one on the classifieds here. Don't forget that Diesel Dynamics sells a very slightly different version of the EZ and Comp.
I bought mine at 47k, put a comp on at 58k, and DD3's are going in at 85K, and bigarse turbo will be next--way before 100k. Oo.
