Any of you folks running a WVO system on a dodge ram want to share how you hooked up the coolant lines? Im trying to figure out where and how is safest to tap the cooling system.
I just purchased a pump, valves and a vormax heater/filter and Im going to use my own tanks and fab my own heaters from aluminum tubing and sheet stock.
Also trying to figure out where to get fittings to bypass the stock filter when running on vegoil. They look like banjo fittings so I guess I need a banjo to open -end and something to go banjo to banjo with a double-drilled/length bolt to patch them together.
