Where's the anti-freeze going?
Fuel Pin
engine block heater
My friend has an '89 W250 and he told me that when he stops after driving around town and back and forth to work he can smell a faint wiff of burnt anti-freeze coming from his truck. He also said that his oil smelled like burnt anti-freeze also, but when I checked it I didn't notice anything out of place. Some guy he knows seems to think that it is the head gasket, but I think he might have a small leak and it may be blowing on to the exhaust. I don't have the truck in front of me like he has so I can't even answer many of my own questions. Any help would be appreciated.
Mine leaked on the heater hose going into the cab. There is a metal thing on the heater hose ( can't think of what it is called) with a small vacum hose attached to it. It would leak a little anti freeze onto the exhust manifold. I replaced it with a napa one and no more leak. Let me know if that might be it and I will dig up the napa # for the thing.
Doug
Either go to a shop or buy a pressure tester , pumps air pressure into the cooling system [15-20lbs] then look for leaks , hot & cold , the part that DMosher sounds like the vacume valve that lets the coolant into the heater core, that cominly leaks.
Thanks, I'll let Joe know tommorow. A cooling system leak was my guess from the start, but sometimes the best method is to preasure wash the engine compartment and check routinely from there.
