wheres the oil coming from
Had an accident
AFC Questions...
hay guys was workin on the truck yesterday n noticed good fair amount of oil on da passneger fender well, then i took off the air intake hose n there alot of oil in there, does anyone kno excatly where it coming from. thanxz dan
Have you checked to see if your oil filter is on tight? Could also be leaking from the turbo oil supply line on top the turbo or on bottom of the turbo from the turbo oil drain. If there was alot of oil INSIDE your air intake hose, that can't be good. Time for a rebuild on your turbo.
