Where's the reverse light switch for an auto?
Mirrors trade
new member
I'm having to hold up the shift lever on the column when in reverse so that my backup lights come on. Anyone know if their is a switch in the steering column, linkage at the transmission, or worse yet in the transmission itself?
icarus
'98. 5, 2500, 4x4, LB, QC, AUTO, 3. 54 rear, Snugtop, Rhinoliner, ISB, non Cummins enhanced ECM, DDIIIa injectors, K&N, Transgo Diesel shift kit, KJones TC, Autometer boost, transmission temp, digital pyro, Mag-Hytec diff/transmission cvrs. , Redline lubed.
Well I know on the old non OD trannys(which is very similar to the OD units of today. THe swith is on the side of the trans and also doubles as the nuetral safety switch. Its a bix 1+" plug with wires going into near the shift linkage. If its the same its easy to change, you will lose a little fluid though. Hope i could help
Clark
Clark
1999 2500 QC SB 5spd Flowmaster 3 chamber
1968 Barracuda Formula S Viper Blue 11. 98@112
NHRA member for life
Yes, like Clark said, it is in the side of the transmission near the shift lever. The switch it's self is not adjustable but the linkage is. Might just need a little adjustment or might be wear in the grommets.
