How do you tell if you have a 10. 5 or 11. 5 axle?
I also have not located the refill capacities to know how much to buy. I know poeple's opinions seem to vary greatly as far as what to put in there. I was planning to use the synthetic valvoline 75w90 that is at the local parts store. It gets pretty steep if you need 6 or so quarts. Can you order this kind of stuff for delivery or is that out due to combustability?
I'd at least like to find it by the gallon. Might even make sense to get a pail if it takes that much and the front uses the same stuff too. How often are folks changing the front fluid? I've read some folks say they never change it. That can't be right can it? Does the front spin with the front hubs or does it remain still while driving in 2wd? I really don't use 4x4 for any extended driving.
