My neighbor kid has a 97 1 ton dually with a five speed. The other day, the hub tore loose from the clutch disc. We pulled it apart and installed a 13" Southbend Con O clutch assembly. After installation, the transmission will not go into gear. We are thinking the clutch hydraulics are weak enough, it will not push the stronger pressure plate. If this thinking is correct, what should he replace the stock setup with? I found a Wagner assembly for $215 or the South Bend adjustable assembly for $315. Thanks for any input.
J. D.
J. D.
