2nd Gen Non-Engine/Transmission which control arms?
Looking for suggestions on replacement control arms. This is factory ride height, is there any reason to get adjustable arms, or any reason not to?
Looks like hell bent steel has a pretty nice setup but kinda pricey. What others do you suggest?
I would not get adjustable control arms, they open up a lot of room for mis alignment and should not be needed. Metal cloak makes some nice ones too, whatever you get make sure the joints are easy to find when needing to be replaced.
I had the hell bent steel ones on my 2001.5 2500. Very good quality and durable. The only complaint I had was with the Loctite, kind of a pain. Had to install them with out Loctite, take it in to get aligned and then loosen the big nuts back up and apply the Loctite. Also kind of a pain to get the front and rear joints in line and everything tightened up. With that being said after the install I didn't have to touch them again. Just greased at each oil change.
