This should be required reading for all who
might be afflicted by the dreaded BOMBitis.
Taken from Dave Fritz's website at
www.dodgeram.org
( A MUST HAVE bookmark site for the savy CTD owner)
CORRECT ORDER OF BOMBing.
"This was posted to the TDR forum by Ted Jannety, who runs the respected Jannetty Racing Enterprises, Inc. "
1. Guages: boost, Pyrometer, optional transmission temp.
2. K&N air filter in the stock air box or a scotty air system.
3. 4" exhaust turbo to tail pipe, preferably mandrel bent aluminized.
4. Then some sort of fuel enhancements, i. e. Van AAken CPC or larger injectors, but not both at the same time until ...
5. upgrades to the torque converter and valve body on Auto's, or a clutch on a manual
High quality low stall converter, preferably 1600 rpm, and a valve body modifications to recalibrate to handle the extra power. I prefer the Centerforce dual friction clutch on the manuals.
6. Depending on what you choose on #4 finish the job with injectors or Box.
7. 1/2 inch fuel system to feed that hungry powerhouse, and keep that injection pump cool and lubricated.
8. US Gear 20% Overdrive auxiliary transmission so you can use all that new found power. How's 1800 rpms at 75 mph sound?
9. A BD turbo mount exhaust brake to slow her down.
