I've got an 04. 5 3500 srw and I'm having a hell of a time trying to pick a gear and get the sled moving without stalling. It's a pretty new setup with a SB DD 3600# clutch, HTB2 64, 3. 73 gears, 285 mud tires, a bunch of other goodies, and I'm putting out over 550hp and 1025 tq. I'm looking for some input from others pulling with a 6speed and similar horsepower output. I'm not new to pulling but like I said this is a new setup and I've only pulled it twice.
Here are my failed two attempts so far. The first time I tried it in 2nd high, dumped the clutch to soon, and got under the turbo. I didn't stall it but I just said screw it and kept the throttle open. At about the 75ft mark the turbo spooled up and the truck took off. When the turbo did spool up I could tell I needed a higher gear because the rpms kept running up to 3200 and I had to back out of it(still placed 4th). The second pull I tried 5th low which is between 2nd and 3rd high. I dumped the clutch to soon and stalled it. I'm getting very frustrated.
I need some feedback as to which gear to try and advice on keeping the turbo spooled when taking off.
