Engine/Transmission (1994 - 1998) Which is better for front cover gasket
Engine/Transmission (1998.5 - 2002) Best gasket for front cover
2nd Gen Non-Engine/Transmission Helpful hint for us all?
I am doing the front cover and KDP. I ordered the kit from TST It comes with ultra grey silicone for high vibration. I am a fan of the right stuff silicone which one is better?
My experience has been to only use silly cone when you come to corners with gaskets ,
The right stuff is close to what the manufactures use when assembling eng. & not using gaskets , it holds on almost to good , bend sheet metal covers when removing , then clean up is the most labor intensive , also the bits & pieces go everywhere .
If you leave about 4 - 6 bolts in , but out about 3 turns , then tap on cover from side to get the seal to break free , the best to reuse a gasket is permatex gasket sealer & brush on .
