Engine/Transmission (1994 - 1998) which line is fuel feed which is return
Engine/Transmission (1998.5 - 2002) FASS, 1st Impressions
2nd Gen Non-Engine/Transmission plugs under dash
doubke checking everything, which line out of the tank front or rearmost is the feed, and does here does the feed line go to the motor at?? Thanks for the help Travis
The supply line goes to the lift pump assembly. It connects to a fitting on top of the fuel heater which is just in front of the lift pump. The line from the top of the lift pump goes to the rear fitting on the fuel filter.
