HarrisC.
There are a number of things to keep in mind when choosing a motor oil. Where you live? How much driving you do? Towing commercially & heavy?, Etc.
If you live in a cold climate, the 5WX40 may be a good choice.
If you do a lot of driving, the advantages of extended oil drain intervals, that a synthetic offers, may apply to you.
If you tow heavy, the synthetic may be easier on your engine & allow you to go further without changing the oil.
If you are going to change the oil every 5000 miles, like you seem to be doing, you will be throwing out good, expensive oil if you go to a synthetic. In that case, a conventional (dino) oil will work well, for you.
There is nothing wrong with conventional oils. Many of them have very robust additive packages that allow them to live a long, useful life protecting your engine. There are Cummins engines "floating around" with well over a million miles on them, without a rebuild, using conventional oils & reasonable oil change intervals.
Personally, the last two oil changes I did were at the 8000 mile interval. I did used oil analysis & the results showed the oil was still in good shape. I'm thinking of extending the next change to 9000 miles, test, & see what the results are. This was with Chevron Delo-400, 15wX40, CI-4 &, CI-4+ on the last change.
The Delo has a very nice additive package that, now, includes moly & boron, which, add a protective layer on the metal surfaces of the engine. They started that with the newer CI-4+ rated oils & you could see the moly & boron in the analysis. Also, Delo is available at Costco, Sam's Club, Walmart, etc. , usually at reasonable prices.
From the reading that I've done, you will get the biggest "bang for your buck" with synthetics if you do a lot of hard driving, as in commercially, towing trailers, etc. If you combine an oil bypass filtration system, along with a quality synthetic oil, & used oil analysis, you will be able to do extended oil drain intervals, safely.
Remember, if your engine is still under warranty, you still have to follow the manufacturers guidelines for oil change intervals. (Some say that if you can prove the oil is in good condition, through analysis, you don't have to follow the manufacturers guidelines but, I'm not so sure. )
Another consideration is that, if you "just feel better" about using a synthetic oil in your engine, even though it probably does not need that much protection, & the extra costs won't hurt your wallet, then "go for it".
Good Luck, with your decision.
Joe F. (Buffalo)
