Which Oil
I just drilled a huge hole in my truck!
Gooseneck hitch installation
It is now time for me to change the lubricant in both rears and the transfer case. I've already done the 5 speed using the GM lube. Looking for recomendations as to what to use. Most driving is high speed with some towing of a 7,000 lb. trailer. Rear dif. is factory limited slip. At 48k miles should I go with petro or synthetic, Amsoil or other product. All suggestions appreciated
Denny
More important than the brand is that you stick to one brand until when or if you switch to synthetic. I like Delo 400.
95' 25004X4,AT,Driftwood,Banks,Warn fender flairs and running boards(Play truck)95 3500,5 speed,driftwood,Banks&phscotty,34,000 GVW apple and tractor hauler(work truck)
Denny.....
My truck also has 48k miles on it and is in need of axle/transf. case lub change.
Decided to go with Ammsoil synthetic 75/90 (GL-5)in the differentials. Add 3 tubes of Mopar positraction additive if you have a Dana 80 with positrac.
I also have Amsoil synthetic ATF for the transfer case change.
Will stick with Shell Rotella-T in the engine as it is easier to obtain when traveling.
Good luck in your lubricating search.
1998. 5; 24v,3500,4x4,SLT,QC,5 spd,3. 54LS, 4 whl. antilock, all options available when ordered, 18k lb. Reese full tilt 5th whl. hitch, oem full length diamond plate running boards, eyebrows & hood dam, bed edges,bedhooks; gray Rhinohide liner, Pac Brake, britebox,"deepdish"mats, matching topper shell, Sandstone(looks gray to me) & camel leather, stainless fender eyebrows, chrome(and road tar) exhaust turndown pipe; brush guard, SPA digital boost/egt(pre-turbo) gauge and pillar mount.
Lowered rear end 4" to set truck level.
See My Truck
1980, W200 Powerwagon, regular 4 door crewcab, 360 gas, auto, 68k original miles, 4 coats of Zeebart but losing ground to the saltwater anyway.
<A HREF="http://www.geocities.com/jr_fish_head/Orange_truck.jpg" TARGET=_blank>
The Powerwagon </A>
<A HREF="http://www.geocities.com/jr_fish_head/The_boat.jpg" TARGET=_blank>
My Boat </A>
I too use Amsoil in the engine plus all gear boxes. At each change I do an oil analysis which indicates good results in all areas. Oil is changed every 6000 miles trans(5speed) and diff at 18,000 mi.
Good Luck
Happy Trails
'93 Banks Power pack, K&N air filter,BD Power injectors and tweaked pump. 27 lbs. boost unloaded.
