I'm in the market for a grinder to do some finish work after welding. There are basically two kinds of pneumatic grinders I've found, but they are significantly different. Having no experience with them, could someone recommend which one to get to finish off a piece after welding?
Here's the first type:
3102 Super Duty
This type has 1/3 hp and a 20000 rpm free speed and you can use various tools such as grinding stones and sanding pads on it - kind of like a Dremel on steroids.
Here's the second type:
3445 Super Duty
This is a larger tool at . 8 hp and only spins at 12000 rpm. It looks like it only takes 4. 5" grinding wheels.
I'll be grinding on 12 ga sheet metal and up to 1/4" mild steel for now. My compressor is a 60 gallon vertical IR with 15. 8cfm @90psi output. I haven't even fired it up yet and have to wire it up in the garage as it's 230 volt. I've got to put a sub-panel out in the garage to run the welder and compressor. (Sears had a red tag on the compressor one day and I stole it from them for $500 -couldn't pass it up)
I had been hesitating to do this because we were thinking of moving, but I could end up waiting for months to start using all these tools! The next guy will appreciate the sub panel out there if he spends any significant amount of time out in the garage.
3102 Super Duty
3445 Super Duty
